1996 Pontiac Grand Am P0140
QUIETMAN928
Hi to both of you! My name is Chip and I am a disabled ex-class A Tech. I have started a ministry out of my church where I work on (and hopefully fix!) peoples cars for no labor charges. Through donations to the ministry we even purchase the needed parts if the owner is really destitute. Eventually I hope to take in donated cars that need repairs and, after making them roadworthy, re-donate them to people who otherwise can't get a job or be self sufficient.(We have no mass transit here) I'm finding it to be a really rewarding experience to see the looks on their faces when I'm through and there's no bill. Now I have a question for you, if you would be so kind. I'm working on a '96 Grand Am with a 2.4 and about 126k that when I first got it was blowing BLACK soot and smoke out the tailpipe. It had a code of P0140, no activity on the downstream O2. After replacing a bad fuel pressure regulator and the plugs, I replaced the sensor, since it was so covered in carbon it never would have worked. The car now ran fine, mileage doubled, and we were all happy. I did tell them that the converter may have been damaged by running it for a while with all that excess gasoline going through, and they said they had already replaced it. I somehow didn't ask if it was replaced before or during the black smoke. Now comes the fun part: I got a call back from them that the CEL was on again, although the car was still running fine. I pulled DTC P0140 again, removed the sensor thinking that some remaining carbon had fouled it again. It appeared to be in good shape but since it was under warranty I replaced it again, then watched it on my scan tool. The voltage was at .440VDC which is in the right range, but it never changed even a thousandth of a volt, under any condition of load or throttle. I unplugged it from the harness and the reading STILL said .440VDC! It didn't set a code or even flash the CEL or affect the running at all. I don't see how the scan tool could still be seeing a voltage reading when the source of voltage was removed. I checked the continuity of the signal wires to the PCM and for any shorts to power but could find nothing wrong. My sense now is that it must be the PCM, but I don't know how to prove it. Also the parts place says they keep the original PROM, they just put it into the new PCM. Please help me out, and tell me what to do. If you do, and I understand that you get tons of questions, how will I know that you've responded? Thank-you for taking the time to read this, it's good to know that there are other people helping strangers. Chip from the TUMC Car Repair Ministry.
eMail: ut4jc@yahoo.com
Apr 3, 2006 at 11:21 PM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. :)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
Some quick O2 facts.
~ O2 sensors generate their own voltage as far as the PCM is concerned.
~ Sensor 2 has no affect on the air/fuel mixture.
Check the O2 @ the exhaust manifold. Suspect the cat is bad again.
There are a lot of folks that help thru this forum. Some pros, some retired pros, some soon to be pros (students), some home mechs that are here to help and learn, like myself. All made possible thru our sponsors. Support them if you can. What the heck, hit them up for a donation too. :)
The best way to get advice is to post in the proper forum section.
GM in this case. https://www.2carpros.com/forum/general-motors-repair-questions-vf9.html
Also when threads posted in any section are replied to an e-mail is automatically generated. It is then sent to all posters of the thread.
Good luck with the Grand Am and your ministry. Let us know how it goes. 8)
Apr 4, 2006 at 4:51 AM
PEPPERMRJ
  • 1,158 POSTS
Mystery voltage please sign in. Now for the rest of the story.
The oxygen sensor (O2S) consists of a zirconia electrolyte between two platinum plates. When the sensor reaches approximately 318ºC (600ºF) it becomes an electrical source that responds to the oxygen content in the exhaust. The PCM produces a bias voltage of approximately 450 millivolts on the oxygen sensor circuit. When the sensor is cold its internal resistance is extremely high, therefore the PCM recognizes the bias as an open circuit. As the sensor warms
up, the internal resistance decreases. When the sensor reaches approximately 318ºC (600ºF), it starts producing a voltage based on the oxygen content in the exhaust system. This voltage is used by the PCM to determine a rich or lean oxygen sensor signal and adjusts the fuel mixture accordingly.
This was written in regards to OBDI Saturns. Seems to fit your GM issue. Did you check the heater circuit for that rear O2?
Goo luck and post back. :)
Apr 7, 2006 at 2:46 PM
Suggested Repair
Treat the steady 0.440 V reading as normal PCM bias voltage, which can remain with the sensor unplugged or cold. Check the downstream O2 heater circuit, and inspect the catalytic converter, which may have been damaged by the earlier rich condition.
Conversation Summary
A 1996 Pontiac Grand Am 2.4 had P0140 after blowing black smoke from a bad fuel pressure regulator. Replacing the regulator, plugs, and downstream O2 sensor restored drivability, but P0140 returned. Scan data stayed near 0.440 V even with the sensor unplugged, and wiring checks found no short. Experts explained that the PCM applies about 450 mV of bias on the O2 circuit, so that reading does not prove the PCM is bad. They advised checking the rear O2 heater circuit and suspecting a damaged catalytic converter.
