2005 Pontiac Grand Am starter
2005 PONTIAC GRAND AM
MOLDBOARD
Electrical problem
2005 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 63000k miles
car won't start. starter and battery good. wire to solenoid on starter has no power to it. checked fuses good. cheked grounds good. turn key to start and nothing happens.
Dec 20, 2008 at 10:20 AM
BMRFIXIT
  • 19,053 POSTS
Two wires at the starter solenoid big wire and its supplied battery power
and small wire
( it should have power when key in start position )
if its the small wire you having problem with
check the neutral safety switch
check ignition switch
Dec 20, 2008 at 10:50 AM
