2005 Pontiac Grand Am Noise in front end
2005 PONTIAC GRAND AM
90,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVESMITH1107
I have a noise that starts when the car starts moving. It gets louder as the car increases in speed and is at it s loudest at about 70km/hr. I have recently had the front tires changed and that did not help. It is not the engine as the sound decrease and increases as the vehicle decelerates or accelerates. The vehicle performs great. there is no shimmys or pulling in the steering. THe noise however does go away when i turn to the right and returns when i am going straight or gets louder when I make a adjustment to the left.
Jul 11, 2008 at 11:13 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds liek the r/f wheel bearing/hub assembly. Have replaced a ton of those for noise and other problems.When you turn right you take some load off the r/f wheel and the noise will change, left is more weight on the r/f and the noise will get louder
Jul 12, 2008 at 1:15 AM
