No heat from heater?
CHARDY86
  • 2003 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 102,653 MILES
First I noticed the heater was not blowing hot, a day later engine running hot and low coolant light on 2 mos ago we had to put a new water pump on and also had to put new lifters in, any suggestions
Thursday, December 19th, 2019 AT 1:54 PM (Merged)
JDL
  • 16,098 POSTS
Hi, Are you losing coolant? Check for leaks. Check the heater hoses, see if they are hot? Check for coolant flow through the radiator?
CHARDY86
Losing coolant somewhere, filled the day b4 yesterday, maybe 1.5 gallons, its almost empty today cant see any leaks, I did feel the heater hose 1 hot 1 cold
Thursday, December 19th, 2019 AT 1:55 PM (Merged)
JDL
  • 16,098 POSTS
You may need to check the intake manifold gasket for the coolant leak. As far as the heater hoses, maybe the heater core is blocked or a valve that is preventing circulation through the heater core.
RELLIE89
I have a 2003 Pontiac grand am replace the thermostat and still no heat need help.
Monday, January 29th, 2024 AT 8:29 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,513 POSTS
Do you mean no engine heat or the car's heater is not working?
Monday, January 29th, 2024 AT 10:16 AM
