2005 Pontiac Grand Am Fuel Pump
55,000 MILES • 6 CYL • FWD • MANUAL
2PLYSWIFE
What is the easiest way to change out fuel pump?
Jan 11, 2008 at 5:23 AM
MASTERTECHTIM
  • 4,750 POSTS
bring it to a repair shop!! if you want to do it yourself its not that hard. lets hope your tank is almost empty. i believe the exhaust might be in the way of removing gas tank. you might have to undo the exhaust hangers and push the exhaust to the side. put a jack under gas tank and remove the 2 gas tank straps and lower fuel tank. undo fuel lines and electrical plugs and remove fuel pump. do the reverse to put it back together. i hope this helps.
Jan 11, 2008 at 5:31 AM
