2005 Pontiac Grand Am Fuel Pump
2PLYSWIFE
  • 2005 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • MANUAL
  • 55,000 MILES
What is the easiest way to change out fuel pump?
Friday, January 11th, 2008 AT 1:23 PM
MASTERTECHTIM
  • 4,750 POSTS
Bring it to a repair shop! If you want to do it yourself its not that hard. Lets hope your tank is almost empty. I believe the exhaust might be in the way of removing gas tank. You might have to undo the exhaust hangers and push the exhaust to the side. Put a jack under gas tank and remove the 2 gas tank straps and lower fuel tank. Undo fuel lines and electrical plugs and remove fuel pump. Do the reverse to put it back together. I hope this helps.
Friday, January 11th, 2008 AT 1:31 PM
