2005 Pontiac Grand Am abs light
57,000 MILES • 6 CYL • FWD • AUTOMATIC
ED1966
hello guys
on my 2005 pontiac grand am gt the abs, trac off, and service engine soon lights came on today and i was wondering if you have a possible diagnosis on what the problem might be. i was told it could be a sensor or maybe a bearing problem. my hope is that it's not the abs unit it self. any help would be great.
thanks ed
Jan 15, 2010 at 10:06 AM
MMPRINCE4000
  • 8,548 POSTS
You can have powertrain codes ("P") read for free at most autoparts stores.
ABS codes are "C" codes and can only be read with a chassis scanner. So you will have to get ABS codes read at dealer or trusted garage.
Most likely you are right the ABS codes is a wheel sensor, but a chassis scanner will tell you which one.
Jan 17, 2010 at 12:29 AM
