2004 Pontiac Grand Am water pump removal
FACEPOLO
Engine Cooling problem
2004 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
i would like to know how to relieve the tension on the belt to remove the water pump
Aug 7, 2010 at 9:29 AM
  • 110,246 POSTS
There is an automatic tensionier that rides on a pivot. You will either need a wrench or ratchet based on which one you have. Place the ratchet in the slot made for it and turn the tensionier in the direction to loosten the belt. Remove the belt and release tension. (watch your fingers) Here is a picture of the tensionier. Also, if you need belt routing information, refer to the belt routing diagrams site on this page.
https://images.2carpros.com/forum/automotive_pictures/249084_5_42.jpg
Let me know if this helps or if you have other questions. Joe
Aug 7, 2010 at 5:15 PM
FACEPOLO
thanx! got it off and feel a little dumb for not seeing it in the first place. thanx again
Aug 8, 2010 at 8:53 AM
  • 110,246 POSTS
I'm glad you got it fixed. Also, don't feel dumb. Today's cars are not like the old ones. They can really be a pain.
Let us know if you have questions in the future, and thanks for using 2carpros.com.
Aug 8, 2010 at 5:53 PM
