Car starts fine, engine sounds good, but when the brake is pressed, you can see the lights dim inside and outside, as well as when the heater is running, it reduces. everything seems to power back up when gas is pressed.
My assumption at first was battery, but the car has no problems starting. My second guess is the alternator.
This is the SE2 edition.
Thanks
Thanks
Feb 20, 2009 at 2:25 AM
