2004 Pontiac Grand Am No one knows the problem
RICHBOI_87
Shakes or Wobbles problem
2004 Pontiac Grand Am 6 cyl Automatic 150000 miles
I have an 04 grand am and well for some reason my cars shakes and strains to turn on there is oil or power steering fluid on the belts and alternator but there is no leak from the imediate containers. Is do ya'll know whats wrong with the car?
Jun 19, 2009 at 12:48 PM
  • 31,937 POSTS
HI there,
Remove and clean the belts, (they should be replaced when this problem if resolved) clean the pulleys& wash down the engine, make sure that there are no leaks from the power steering and engine or transmission cooler lines that may be leaking, charge & load test the battery replace if found faulty, check plugs, fuel filter air filter and general tune items, replace belts and run engine checking for any signs of fluid leaks, run a scan to check for set fault codes, start here.
mark (mhpautos)
Jun 19, 2009 at 4:10 PM
