my abs, service vehicle soon and trac off lights come on what should i do to fix this problem?
Apr 6, 2009 at 7:33 AM
NATRONERACER
MEMBER
I would first check the battery connection I had the same problem on my 2001 grand am and it was the the positive battery conection I have to clean mine about every 2 years.
May 31, 2009 at 12:36 PM
LORI FREASE
MEMBER
When i start my 04 grand am ABS, TRAC OFF, SERVICE VEHICLE come on before I even put it in gear. I have a test light and multi meter but not exactly sure what to test
Feb 4, 2019 at 1:48 AM
✓Experienced Mechanic
Nine times out of ten there is a wheel speed sensor that is not working. here is a video to show how to get the codes using a scanner if you don't have a scanner. Here is a guide to help you test the sensors manually:
