2004 Pontiac Grand Am Lights keep coming on
2004 PONTIAC GRAND AM
42,500 MILES • 6 CYL • 2WD • AUTOMATIC
J2
so i get 3 lights that come up on my dash all at the same time. they are ABS, Service vehicle soon, and Trac off.
the trac off button doesnt work when all three lights are on. is there something wrong with my wheels? or i have heard it might be my abs sensor.
any help or suggestions would be great
Mar 10, 2009 at 8:04 PM
MMPRINCE4000
  • 8,548 POSTS
You will have to get car scanned to retrieve error codes, most autoparts stores can scan "P" powertrain codes for free, but ABS and traction control codes are "C" chassis or "B" body codes. You would have to go to a professional shop for these codes.
Mar 11, 2009 at 9:46 AM
RAINZ
  • 12 POSTS
Probably one the most common problems for grand am owners too. Check the ABD connects on both sides in the front behind the hub assembly, chances are there are lose or corroded. Clean them up good and tighten them up if they are loose (i've used duct tape). If they are are corroded, then you'll have to replace the hub assembly, its all one unit, hubs, bearings, and ABS conections. The rear brakes sensors are famous for failing as well, again check the connections.
Mar 12, 2009 at 12:11 PM
