2004 Pontiac Grand Am i need help
2004 PONTIAC GRAND AM
QUEENHB1
2004 Pontiac Grand Am V8 Four Wheel Drive Automatic
my car was making a sound like the hazard lights was on but thery werent and then my steering wheel started smoking. Is that a big problem should i not drive it whats wrong with it
Jul 6, 2008 at 3:32 AM
ADAMPOLING
I am having the exact same problem with my 2005 Grand Am. I think it may be a short in the wiring system that is connected to the turn signal lever. I am going to try and remove the steering wheel to see if I can look behind it to see if there are any exposed wires that may be causing the smoke. Ill let you know what I find out.
Jul 29, 2008 at 7:35 AM
ADAMPOLING
I have looked behind the steering column. I did not see any exposed wires, which makes me think that there may be a short in the wiring harness connected to the turn signal lever. I believe that I have located the problem, and would recommend that it be taken to a dealership or auto maintenance shop to be repaired/taken care of.
Jul 29, 2008 at 2:53 PM
