as soon as i turn on the heater,or defrost or the ac I hear a humming noise.It sounds like it is coming directly from the heat source at the passenger seat where the passengers legs would be at.When i shut off the heat, defrost or ac the noise stops,but immediately comes on again if the usage level is anything above 0. Can u tell me what may be causing this, and can i drive safely with this problem?
Nov 24, 2009 at 10:59 AM
