2004 Pontiac Grand Am Grand Am 2004 electrical problems
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
MONTES12
I'm new to this. Well, its a 4 door Pontiac Grand Am 2004 v6 3.4L. Suddenly, the light from the speedometer/ac/everything inside the car except stereo stopped working which means i have a hard time driving in the night. ALSO The night driving light from the tail lights don't work anymore. They do work when i brake and all of them, but while driving none of them work. ALSO, when i lock the car with the alarm, the lights wont turn on signaling that the car has been locked/unlocked. ALL OF THIS went wrong at the same time... Is it a fuse? Bad wiring? If any, what is it? and thanks in advance appreciate what you guys do.
Apr 28, 2010 at 6:26 PM
MMPRINCE4000
  • 8,548 POSTS
Fuses would be first thing to check. Remove panel inside car and check fuses.
May 1, 2010 at 2:23 AM
MONTES12
[quote:1e765933bd="mmprince4000"]Fuses would be first thing to check. Remove panel inside car and check fuses.[/quote:1e765933bd]
if its not the fuses, then what can it be?
May 1, 2010 at 6:50 PM
MMPRINCE4000
  • 8,548 POSTS
Could be an open circuit in the wiring.
I would also have the battery checked at most autoparts stores for free.
May 2, 2010 at 1:09 AM
