2004 Pontiac Grand Am fuse problem
2004 PONTIAC GRAND AM
YAPPYRED
Air Conditioning problem
2004 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
I have a 2004 grand am. Engine fans wont come on causing engine to over heat. Also aéc wont work. Checked fuses under hood and 30 amp fuse for aéc cooling fan 2 ground wont read.Changed fuse still isn#t registering. What can I do to get fans to work.
Jul 1, 2010 at 5:57 AM
SATURNTECH9
  • 30,869 POSTS
I emailed to your personal email cooling fan inop trouble tree,cooling fan wire diagram and cooling fan operation.If you have a bad ground to the cooling fan relay #2 replacing the fuse won't fix that the fuse only supply's power to the relay not the ground to the relay.Check out the wire diagram i sent and make sure that you have a good ground to that relay.Also post your finding an question's on this posted question you started so other user's can learn from your car's problem's.
Jul 1, 2010 at 7:52 AM
