2004 Pontiac Grand Am drivers side powere window
90,000 MILES • 6 CYL • FWD • AUTOMATIC
MRKALGRIM1
I need to replace the parts in the door panel that attach to the window and also the parts that move the window up and down. The regulator is working fine. I need to know what year grand ams use the same parts. Mine is and 2004 but i can't find one in the junk yard. before i start tearing a different year module apart i was wondering if the parts will be the same? for instance, does a 2000 use the same hardware?
Jun 20, 2010 at 1:50 PM
MMPRINCE4000
  • 8,548 POSTS
Check with GM parts about interchangibility, we do not have access to this info.
A good junk yard can also tell you.
Jun 21, 2010 at 12:19 AM
