2004 Pontiac Grand Am Can't get calipers off
43,000 MILES • 4 CYL • FWD • AUTOMATIC
PHILLYGIRL60
I took the 2 bolts for the caliper off but it still won't slide off. Is there something else I need to remove or take off before it will come off or is it just stuck and difficult to remove.
Aug 27, 2008 at 8:33 AM
MASTERTECHTIM
  • 4,750 POSTS
try gently pressing in on the inside pad where it connects to the caliper. uising a screwdriver pry the caliper piston back and then the caliper will fall off. make sure to use a c clamp or equavelent to completely compress the caliper piston before reassembling.
Aug 27, 2008 at 8:43 AM
