Starter Relay?
75,000 MILES • 6 CYL • FWD • AUTOMATIC
LEBDUDE
I have a Grand Am that starts fine, but after it starts, the radio, windows, fans, and lights don't come on right away. They come on after a short time (30-60 secs). The other day they actually cut out while driving. I am thinking it is caused by the neutral cutout that happens while starting. Is this done in a relay or in the ignition?
Dec 10, 2009 at 11:38 PM
JDL
  • 16,098 POSTS
Welcome, if that is ignition feed to the problem circuits, I suspect the ignition switch. I'd have to check feed to and from the switch. The start position is spring loaded, you have to hold the key in the start position, when you let it go, it springs back to the on/run position.
Dec 11, 2009 at 1:44 AM
PABLO CASTILLO2
Starter won't turn I can't locate the relay location
Aug 1, 2020 at 4:23 AM (Merged)
HMAC300
  • 48,601 POSTS
it's in the under hood fuse box, should be marked on inner side of fuse box cover or manual if you have one.
CARADIODOC
  • 34,413 POSTS
There is no starter relay. The engineers are relying on the ignition switch to carry all the starter solenoid current. A lot of imports do that too.
MAMAGOOSE183
also replaced relay switch on radiator, have had same problem before starter went would turn key on and have all power would have to turn key over and over then all of sudden it would start.
  • 75,988 POSTS
No crank at all/nothing/nada when key is engage to starting position
Could the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery condition and connections are good. Note:If it doesn't apply disregard.
MAMAGOOSE183
How do I re-program the key switch? All other are good. Please send diagram if possible on changing this switch.
  • 75,988 POSTS
You need to check for power on the purple wire while key at cranking position-no power could mean transmission range switch and ignition switch
BIGSUP116
  • 10 POSTS
Electrical problem
1996 Pontiac Grand Am 6 cyl Front Wheel Drive Manual
where is the starter relay located at?
Aug 1, 2020 at 4:24 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
There is no starter relay in this circuit.
JDL
  • 16,098 POSTS
You don't have one. There is a solenoid on top of the starter. The starter solenoid S terminal, should be hot with the key in the crank position. That circuit is wired through the clutch switch. Any testing make sure the tranny is out of gear and the e-brake is set.
BIGKAHONA29
I was wondering where the stater relay is located on this car. I cant find the part online. I ve replaced the starter and battery. Car was running fine when I parked it. Came out a week later to start nothing. When i turn the ignition on everything lights up and when i turn the key all the way the headlamps go out and then when I let go of the ignition they turn back on. Someone had mentioned a ignition switch. If so what does that involve to do. Im a decent mechanic so no need to put things in simple terms.
Thanks KEVIN
  • 75,988 POSTS
You don't have a starter relay-could be the ignition switch or the Park and Neutral position switch. See below
https://images.2carpros.com/forum/automotive_pictures/12900_starter_14.jpg
