2003 Pontiac Grand Am Skipping
51,000 MILES • 6 CYL • FWD • AUTOMATIC
SAMANTHA1122
  • 7 POSTS
My car is skipping very badly, after replacing plugs, and checking wires and coil packs it is still skipping.
Jun 13, 2010 at 12:52 PM
  • 75,988 POSTS
If it's not slipping-do below:
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 13, 2010 at 1:09 PM
