2003 Pontiac Grand Am Rough idle/Rough acceleration
2003 PONTIAC GRAND AM
BLAZED
Electrical problem
2003 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 126*** miles
Symptoms: Car shaking, rough idle, hesitates when accelerating.
Codes: 302 (Missfire in cylinder 2)
Current is going over the wires. I pulled the spark plug in cylinder 2 and it didn't look like it had been firing (it was black not white like the other spark plugs). Changed cyl. 2 spark plug. Doesn't really have the hesitation as much anymore, but now has a rough idle. Does this just mean that the coil for cyl. 2 is bad?
Jan 12, 2009 at 12:16 PM
DOCFIXIT
  • 18,828 POSTS
Most likely the wire if they are OEM then way over due for replacement.
Jan 13, 2009 at 12:19 AM
BLAZED
[quote:f91ce03485="Docfixit"]Most likely the wire if they are OEM then way over due for replacement.[/quote:f91ce03485]
Did you read the part where I said "Current is going over the wires" meaning the wires are fine?...
Jan 13, 2009 at 7:04 AM
