2003 Pontiac Grand Am problems starting--Distributer? Elect
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
BASTERK
I have a 2003 Pontiac Grand Am. It has been having trouble starting, but once it starts its fine. I actually had to have it towed to a mechanic because it wouldn't start. Once there (of course) it started right up, and the guy told me that unless you catch the car doing whatever the problem is--its hard to diagnose it. The car will go days and be fine--then jsut all of sudden not start--it sounds like it will, but it wont turn over. Sometimes if i give the car a little pish, it starts up??? What could be the problem? It almost sounds like something isn't catching??
Mar 20, 2008 at 8:22 AM
SPADE007
  • 37 POSTS
[quote:3057a6bc0f="basterk"]Engine Performance problem
2003 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic 93000 miles
I have a 2003 Pontiac Grand Am. It has been having trouble starting, but once it starts its fine. I actually had to have it towed to a mechanic because it wouldn't start. Once there (of course) it started right up, and the guy told me that unless you catch the car doing whatever the problem is--its hard to diagnose it. The car will go days and be fine--then jsut all of sudden not start--it sounds like it will, but it wont turn over. Sometimes if i give the car a little pish, it starts up??? What could be the problem? It almost sounds like something isn't catching??[/quote:3057a6bc0f] check the crankshaft sensor? It sounds like its on its way out
Mar 20, 2008 at 5:46 PM
