2003 Pontiac Grand Am No pedal after changing breaks and ca
2003 PONTIAC GRAND AM
85,000 MILES • 6 CYL • FWD • AUTOMATIC
CHASER45
After changing breaks and calibers pedal goes to the floor. After bleeding the lines it still goes to floor. I get a steady stream of fluid after bleeding the lines. Any suggestions on how to fix the problem???
Apr 29, 2008 at 11:04 AM
If there's no actual leakage at the lines, calipers and wheel cylinders-check the master cylinder thoroughly might be leaking internally and not producing hydraulic pressure.
Apr 29, 2008 at 11:10 AM
