Computer problem
2003 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
The crank relay dosen't close. When I remove the relay cover and close it manually the engine cranks, gives a pot and keeps cranking till I let the relay open. I've checked the continuity on the relay coil and its ok. I also checked the continuity of the key switch in all positions and it's ok. What else could it be?
Thanks in advance for your help.
Oct 26, 2008 at 2:52 PM
