2003 Pontiac Grand Am Engine won't crank.
SYDNEY GRAY
Computer problem
2003 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
The crank relay dosen't close. When I remove the relay cover and close it manually the engine cranks, gives a pot and keeps cranking till I let the relay open. I've checked the continuity on the relay coil and its ok. I also checked the continuity of the key switch in all positions and it's ok. What else could it be?
Thanks in advance for your help.
Oct 26, 2008 at 2:52 PM
DENNYP
  • 1,824 POSTS
Have it scanned for codes with a Tech2 scanner. It sounds like you have a passlock sensor problem.
Oct 28, 2008 at 8:26 AM
