2003 Pontiac Grand Am Car turned off on own
2003 PONTIAC GRAND AM
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREENIS21
I was driving a good 45 minutes when the oil pressure light and the battery charge system light went on and the car went dead. I have just changed the battery two months ago so i don't think that was it plus the power did not go out. But i had not changed or checked the oil in about 6 months. After i coasted over to the side i turned the car completed off and then turned it back on and it did turn on. I continued driving and it started puttering but did not turn off. So my question is what could is possiable be wrong with the car
Aug 29, 2008 at 6:43 AM
MASTERTECHTIM
  • 4,750 POSTS
if your low on oil then your engine is probably damaged. running a engine out of oil even for a minute will do irreversable damage.
Aug 29, 2008 at 6:47 AM
HPXHARDCOREPUNK
  • 9 POSTS
Were the lights dimming while driving? Radio shorting out, a sickly beep that faded away and then came back? I had this problem on a 1996 Chevy Blazer, it turned out to be a bad alternator. The car would start, but only drive for about 5 minutes then die, the alternator couldnt keep the car charge, but the battery was fine to start the car.
Aug 29, 2008 at 6:49 AM
GREENIS21
No.. I changed the oil this morning and it did have about 4 quarts in there.
[quote:fca9de5378="mastertechtim"]if your low on oil then your engine is probably damaged. running a engine out of oil even for a minute will do irreversable damage.[/quote:fca9de5378]
Aug 29, 2008 at 7:32 AM
GREENIS21
there was nothing like that happening just completly quick running.
[quote:7a5e01111d="HPxHardcorepunk"]Were the lights dimming while driving? Radio shorting out, a sickly beep that faded away and then came back? I had this problem on a 1996 Chevy Blazer, it turned out to be a bad alternator. The car would start, but only drive for about 5 minutes then die, the alternator couldnt keep the car charge, but the battery was fine to start the car.[/quote:7a5e01111d]
Aug 29, 2008 at 7:34 AM
MASTERTECHTIM
  • 4,750 POSTS
does the vehicle crank over? if it does we need to know if you have spark and fuel pressure. you can check spark by placing a screwdriver inside spark plug side of wire and place near ground and crank engine and see if there are any sparks.
Sep 2, 2008 at 8:26 AM
