2003 Pontiac Grand Am are these symptoms of the heads going
2003 PONTIAC GRAND AM
113,000 MILES • 6 CYL • FWD • AUTOMATIC
ASHLEY222
hi guys, i replace the intake manifold 4 months ago, under the advise of local monroe mechanics, my car was always losing coolant and would occasionally overheat expensive job, at the time he said my heads were wet and may need to be replaced. well my low coolant light came back on withine 2 weeks of replacing manifold, and i have slowly been losing power. but the water reservoir always looks wet, and it doesnt over heat at all. it is very hesitant when first starting have to keep revving engine to keep it from stalling, the rpms drop like mad, it calms down the further a go along the road but it doesnt have any pick up and the rpms continue to drop spiractically. whats your best guess?
Dec 1, 2009 at 9:31 AM
MMPRINCE4000
  • 8,548 POSTS
Have a compression test perfromed to rule out/in headgasket problem.
This year engine was known for intake manifold leaks.
Dec 3, 2009 at 12:11 AM
