2002 Pontiac Grand Am water pump
2002 PONTIAC GRAND AM
199,000 MILES • 4 CYL • 4WD • MANUAL
HUGGZABLE33
Had a leak under the car was diagnosed water pump. Friend replaced the water pump and the thermostat. Now there is no leak and at moment no overheating. but after changing all this out when car is cranked and the gas is pushed you hear a whining noise. Ive been told that the water pump that we got is bad. that the barren in it is bad. What is your opinion?
Jun 5, 2010 at 12:13 PM
MMPRINCE4000
  • 8,548 POSTS
It is possible that the pump is bad, they are warranted, remove and warrant the old pump for a new one.
Make sure tha pulleys are clean, coolant can contaminate the pulleys and cause squeaking, whining.
Jun 6, 2010 at 12:11 AM
