2002 Pontiac Grand Am WATER LEAK
2002 PONTIAC GRAND AM
113,000 MILES • 4 CYL • 2WD • AUTOMATIC
JANICE J.COBB
My 2002 Grand -AM started leaking water under the
right front part of the car.I had to add anti freeze
twice 4 days apart.The fluid on the ground is clear not
green like antifreeze. Is their a problem with my water pump or my thermostat? The temp gauge
moves ito hot in heavy trafic but never actually
ran hot on me.
Apr 28, 2008 at 7:08 AM
MERLIN2021
  • 17,250 POSTS
Water at the right wheel area is the A/C drain, as for where your coolant is going, have the radiator pressure tested, this will find the leak.
Apr 28, 2008 at 7:13 AM
