What is the timing chain replacement interval
2002 PONTIAC GRAND AM
JHAYES55
Engine Mechanical problem
About when to change the timing CHAIN on a 2002 pontiac 4 cyl.
Oct 30, 2009 at 2:29 AM
MMPRINCE4000
  • 8,548 POSTS
To answer your original question, there is no specific mile or time period to replace a timing chain, having said that, I would certainly inspect the chain every year. Look for abnormal wear on teeth or links that are deformed, also inspect chain for any debris from guides.
If you did the work yourself, it is far cheaper to replace the chain than the engine.
Oct 31, 2009 at 2:45 AM
