2002 Pontiac Grand Am timing chain
ALNOW7176
  • 2002 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 85,000 MILES
My GA broke down and upon inspection, I found that the timing chain snapped. I bought a repair kit a replaced all the necessary parts. Chain, gears, adjusters. I set the cam to TDC and done everything right.
When I tried to start it I got the same reaction from the motor. Everything is turning and it seems that there is no compression, that the top end is only working, this is very frustrating to me. Pistons are going up and down, cams are moving. Valves are working too. Are there any internal gears that might have gotten stripped out when the chain broke? Or on the crank shaft? Thank you for your time
Sincerely,
Al Nowak
Tuesday, November 10th, 2009 AT 7:43 AM
KNOWYOURAUTO
  • 113 POSTS
Interference engines: You sound like a mechanically inclined individual so this will be short. This model engine has had a lot of these failures with the same result. Replace the engine.
When the timing chain broke the valves came into severe contact with the pistons and were probably bent along with the pistons connecting rods. Of course the avenue of entire rebuild may fix it assuming the cylinder walls were not scored or dented but not very likely.
BTW this engine is in the Chevy Cavaliers, Malibu's, Saturns and Pontiac Sunfires, all of them having similar problems but no recalls for free fixes. The valves and timing assembly have been updated, so I don't recommend a used engine and the same problem may result.
Regards,
KnowYourAuto
Saturday, November 14th, 2009 AT 10:41 PM
