2002 Pontiac Grand Am Noise on driver side
55,000 MILES • 6 CYL • FWD • AUTOMATIC
AWYATT
I have a rattling noise under the hood when I go over a bump. It just started and is only noticeable when driving at slow speeds. It seems to be coming from the driver side, maybe under the hood. It sounds almost like a creaking noise. I'm afraid the motor is going to fall out or a wheel will fall off! Also, when I drive in a confined area like an alley, I hear squeaking sounds coming from the wheels??
Any clues? I would like to have an idea before I go to a mechanic!
Feb 25, 2009 at 5:14 AM
MMPRINCE4000
  • 8,548 POSTS
Raise car put on stands, grasp each tire and push/pull both horizontally and vertically, looking for any movement, which would indicate bearings, ball joints, bushings or loose struts.
Feb 27, 2009 at 1:08 AM
