2002 Pontiac Grand Am No compression engine compression on
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOABSOTO
I was driving my car at a speed of 70mph for about 40 minutes with no noticeable sines of car problems when the engine suddenly just turned off. I cannot turn it back on the starter, fuel pump, spark plugs, and battery works. I check all four valves and there is no compression. what is wrong with the car, how can i fix it and how much can it cost.
Mar 25, 2010 at 11:56 AM
MMPRINCE4000
  • 8,548 POSTS
If you have no compression, then check timing chain.
Mar 25, 2010 at 11:51 PM
