2002 Pontiac Grand Am Leaking Water Pump...
14,500 MILES • 6 CYL • FWD • AUTOMATIC
GOTTAKEEPMOVIN'
  • 42 POSTS
Can anyone please direct me to somewhere that I can find a replacement procedure for my 2002 Grand Am SE, 3.4L, 6 cyl. Also, a part placement diagram would be ideal, just so I can verify that it is the water pump that my antifreeze was streaming out of this afternoon. I ran the car through my local ECheck this morning, and they kindly blew the seal out for me, as it was coming out pretty good when I got right home. I checked the car's coolant just this morning, and it was at the proper level. Any help would be greatly appreciated as I have a daughter 20 miles away and a job 30 miles the other way that I cannot get to now. Thanks, in advance...
Aug 4, 2008 at 7:10 AM
DOCFIXIT
  • 18,828 POSTS
You should have a coolant system pressure test done to locate leak. As for instruction
http://www.2carpros.com/kpages/auto-repair-manuals.htm
Good luck
Aug 4, 2008 at 7:33 AM
