2002 Pontiac Grand Am ignition switch
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALIENBABY40
the car just quit running while we were driving and now it will not start. when you turn the switch every thing comes on at full charge but when we try to turn it over nothing happens the fuel pump dont run the starter wont engage but it works it was tested and the fuel pump also. could it be the switch?
Nov 8, 2008 at 8:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It is possible that the ignition module is faulty. There may be a short in the ignition wires. Test the wires (located in the steering column) and also check your fuses and relays. Post your results and I will follow up.
Nov 8, 2008 at 6:07 PM
