2002 Pontiac Grand Am front end humming
MIKEY76
  • 5 POSTS
Noises problem
2002 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 100k miles
I replaced both wheel bearings no change.Noise starts at about 20 mph.When wheel is turned to right noise gets louder.Right side tie rod is a little loose.Would this cause humming noise though?CV boots are in good condition,so are brakes and rotors,ball joints etc.Can not see tire rubbing anywhere.Could cv shaft still be bad.Thanks
Oct 22, 2009 at 8:56 AM
MMPRINCE4000
  • 8,548 POSTS
A loose tie rod will cause toe alignment to be off and could cause humming.
Start by replacing tie rod end.
Try this also:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Oct 24, 2009 at 3:35 AM
MIKEY76
  • 5 POSTS
Thanks for the info.I will replace the tie rod.
Oct 24, 2009 at 4:40 AM
MMPRINCE4000
  • 8,548 POSTS
Mark the tie rod end so you can get it close to alignment, but you should get the toe checked at an alignment shop.
Oct 25, 2009 at 12:12 AM
MIKEY76
  • 5 POSTS
Thanks again i will do that.
Oct 25, 2009 at 12:19 AM
