2002 Pontiac Grand Am faulty door switch?
2002 PONTIAC GRAND AM
133,000 MILES • 6 CYL • FWD • AUTOMATIC
POWER_LINE
I AM WONDERING IF I HAVE A FAULTY DOOR SWITCH BECAUSE THE DOME LIGHT STAYS ON. THE DOME ITSELF HAS 3 SETTINGS, ON-DOOR-OFF. WHEN ON DOOR SETTING, THE LIGHT SHOULD COME ON WHEN THE DOOR IS OPENED AND GO OFF AFTER 10 SECONDS HOWEVER IT STAYS ON CONTINUOUSLY. IT WILL GO OFF AFTER 20 MIN. BECAUSE OF A BATTERY PROTECTION FEATURE. EVERYTHING ELSE WORKS FINE SO I AM NOT SUSPECTING A BODY CONTROL MODULE? SO, HOW DO YOU CHECK FOR A BAD DOOR SWITCH, AND HOW DO I FIGURE OUT WHICH DOOR IT IS? I HAVE TOOLS JUST LACK OF KNOWLEGE. ALSO THE DOME LIGHT COMES ON SOMETIMES INTERMITTEDLY WHILE DRIVING IN THE "DOOR" SETTING. THANKS
Feb 21, 2009 at 7:19 AM
JNOVACK
  • 723 POSTS
youwill need to check each Door Jamb Switch they are the push button switchs abotu half way up the door frame on eather the hinge side or the lock side of door jamb you will have to remove each one and test with volt ohm meter for continuity if when the button is pushed in and you still have continuity then that switch is bad
Feb 21, 2009 at 1:07 PM
