2002 Pontiac Grand Am Fast Pad Wear
2002 PONTIAC GRAND AM
101,000 MILES • 6 CYL • FWD • AUTOMATIC
SHOOTINGHOWES
I replaced the front brake pads and rotors with middle of the road pads. They had a lifetime replacment warrenty. 6 months later those pads were almost metal to metal. I replaced them again, the auto store said the calipers were bad. I disagree because it was both sides that went bad. When I replaced them I noticed that the brakes were spongy and the car didn't stop like it did before. I had to push harder. I also noticed that they didn't release quickly. Now a couple more months later the rear brakes are making a grinding sound. I have not bleed the brakes but I don't think it will help. I believe the problem could be in the Master cylinder or the ABS. What could it be and how would I test this.
Nov 24, 2009 at 6:01 AM
MMPRINCE4000
  • 8,548 POSTS
Check the caliper slide pins for free movement, if not releasing they will cause premature wear.
Nov 26, 2009 at 10:21 PM
SHOOTINGHOWES
I wired brushed and lubed all moving parts, with no effect
Nov 30, 2009 at 1:16 AM
MMPRINCE4000
  • 8,548 POSTS
Are the rotors smooth, no grooves?
What type (brand) of pad did you use?
Nov 30, 2009 at 11:41 PM
SHOOTINGHOWES
I think they were wagner pads. I'm not sure about the rotors. When I did the warrenty replacement the rotors only had very minor grooves.
Dec 9, 2009 at 1:01 AM
MMPRINCE4000
  • 8,548 POSTS
Then the calipers are binding or you may have a proportioning valve/ABS problem.
I would start by completely flushing the brake hydraulic system, then bleed all four wheels.
Dec 10, 2009 at 12:58 AM
