2002 Pontiac Grand Am fANS
111,810 MILES • 6 CYL • FWD • AUTOMATIC
ARIYA
I recently had my water pump changed and I stopped gettig heat. Took it back and they replaced my thermostat. Still not getting heat car ran hot and fans will not come on.
Jan 25, 2010 at 6:30 AM
  • 75,988 POSTS
Recheck the thermostat, heater core if its clogged-up, radiator -heater control valve if it has one, coolant level, air in the system, engine coolant temperature sensor/gauge switch and fan relay
Jan 25, 2010 at 7:54 AM
