Yes this could be an ignition problem. First, when was the last time you had a tune-up? If it's been past 50K miles, have that done first. If the problem persist, then have the coils checked. The coils do eventually go bad. But don't just replace the coils, check them first.
If the coils check out fine, check the fuel filter, pump and regulator.
SPONSORED LINKS
Saturday, September 25th, 2010 AT 6:05 PM
