2002 Pontiac Grand Am brakes
2002 PONTIAC GRAND AM
108,000 MILES • 4 CYL • FWD • AUTOMATIC
JJBB1000
when i push on my brake pedal it is really hard to push. I have put new brake pads on my car and a new power booster neither have solved or helped the issue. my brake fluid is full, and the anti lock brakes still work. The pedal just wears you out to push it.
Aug 24, 2008 at 8:06 AM
MERLIN2021
  • 17,250 POSTS
Did you install a new check valve? And check vacuum at the booster vacuum line?
Aug 24, 2008 at 8:35 AM
