2002 Pontiac Grand Am Body Control module
178,745 MILES • 4 CYL • FWD • AUTOMATIC
MAMABEAR03
My car starts but anything on the dash board such as spedometer, gas gauge, heat gauge needles will not move. My mechanic mentioned it was not the fuses but the body control module that I have to take to the dealer.Any suggestions?
Jan 17, 2010 at 5:11 AM
MMPRINCE4000
  • 8,548 POSTS
If BCM is malfunctioning it should set a "B" error code, which your mechanic should be able to read with the proper scanner.
I would check all fuses first before replacing the BCM.
Jan 19, 2010 at 12:50 AM
