2002 Pontiac Grand Am aircondition/heater control
HORIO70
Heater problem
2002 Pontiac Grand Am Two Wheel Drive Automatic 95000 miles
Please suddenly my off/on button it works only on the hi spot the 4,3.2,1 they are not working
the heater and aircondition are working only on the hi
I checked all the fuses except the one I think is located on the heat resistor assembly on the heating motor can you please telll me how to get to that or if i have to change the control assebly how to remove it or what could be the cause
thank you
Ted
Sorry your answer was wrong there is no switch only the air condition/heating control the answer to my problem was to replace the fan motor resistor the part $29 plus $50 for labor
Oct 19, 2008 at 6:56 PM
JNOVACK
  • 723 POSTS
if fan switch only works on high it would be the switch then the switch or control panel needs to be replaced
Oct 20, 2008 at 2:23 PM
