2001 Pontiac Grand Am Wires connecting fuel injectors.
2001 PONTIAC GRAND AM
200,000 MILES • 6 CYL • FWD • AUTOMATIC
FLYBOY44T
When I was removing the fuel injectors I disconnected the wires on the injectors without numbering them. oops. Is there a way to tell which wire goes where when I try to reassemble the injectors? The only thing I can think of is looking at the natural bend in the wires and try to figure out where they go that way. Thanks Mark
Oct 21, 2008 at 4:51 AM
MMPRINCE4000
  • 8,548 POSTS
Generally when you drape the harness over the injectors they "fall into place".
Also check the injector connector, some GM engines are marked with the cylinder number on the injector connector.
Oct 22, 2008 at 2:26 AM
