2001 Pontiac Grand Am transmission jumps into geer
2001 PONTIAC GRAND AM
50,000 MILES • V8 • 2WD • AUTOMATIC
AL WESTON
one mechanic said that the computer regulates when the trans should shift and that we need a new computer but another mechanic never heard of this. Can you tell me the answer. Also not sure on the difference between automatic and manual trans---this car does not have a clutch--its your basic prndl thanks al
Oct 24, 2009 at 1:45 AM
MMPRINCE4000
  • 8,548 POSTS
Shifting is controlled by PCM, but that does not mean you need a new PCM.
If you are having shifting problems, it could be a shift solenoid, low fluid level etc.
Have a trans shop diagnosis problem, but check fluid level first.
Oct 24, 2009 at 3:07 AM
