2001 Pontiac Grand Am rouph idle
2001 PONTIAC GRAND AM
100,000 MILES • 4 CYL • FWD • AUTOMATIC
MOTOXKEY
runs great at high r p m s idles rough and stalls replaced the map sencer new plugs new fuil fillter cleaned fuil injecters checked for vac leaks
May 8, 2009 at 1:25 AM
MMPRINCE4000
  • CAR REPAIR CONTRIBUTOR
  • 8,548 POSTS
Could obvisouly be many things, but I would remove and clean the EGR valve. EGR flow at idle will cause rough idle and stalling, but will run better at higher RPM.
EGR valve pintle and base can get clogged/stciking caused by exhaust soot buildup.
May 8, 2009 at 7:35 AM
