2001 Pontiac Grand Am replace engine
125,000 MILES • 4 CYL • FWD • AUTOMATIC
JMCMIN1
I need to replace the engine in my
grand Am 2.4 we have a you pull yard here. I need to get instructions on how to do this.
Oct 24, 2008 at 7:53 AM
JNOVACK
  • 723 POSTS
you unplug all wires going to engine the a/c pump, and power steering pump, gas line then jack car up put on jack stands start removing the wires from the starter and the exhaust pipe and bolts from the engine to the transmission and lower engine mount then lower the car and finish removing the rest of the bolts from the engine to the transmission using a cherry picker or something strong to lift the engine chain to the 2 engine hooks on top of engine one on front and the other on the back remove top engine mount while supporting with lifting device then wiggle engine loose from transmission and lift out
Oct 24, 2008 at 8:22 AM
