2001 Pontiac Grand Am oil leaking
115,000 MILES • 6 CYL • FWD • AUTOMATIC
MICHAELBIELARCZYK
There's an oil leak coming from somewhere. I'm losing about a quart very 2 to 3 days.I cannot seem to find where it is coming from. I've check the oil pan, head cover, oil filter.
Dec 22, 2009 at 4:27 AM
KGMITTER
[quote:9c228fc58b="michaelbielarczyk"]Engine Mechanical problem
2001 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 115000 miles
There's an oil leak coming from somewhere. I'm losing about a quart very 2 to 3 days.I cannot seem to find where it is coming from. I've check the oil pan, head cover, oil filter.[/quote:9c228fc58b]
I have the SAME problem. It only happened recently.
Have you checked to see if the oil plug loosened?
You should check to see where exactly is the oil leaking from. If it is leaking from the top back of the engine it could either be a gasket blown or the valve cover gasket needing to be replaced. Either or, the part isn't VERY expensive but the labor put into it can be ridiculous. I hope you find out what is wrong, I'm still searching for a solution myself.
Good luck.
Jan 4, 2010 at 2:45 PM
