Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Am
Engine
Symptoms
Oil Leak
2001 Pontiac Grand Am oil leak
2001 PONTIAC GRAND AM
170,000 MILES • 4 CYL • FWD • AUTOMATIC
JUNEBUGSUMMER619
MEMBER
1 POST
very bad oil leak so bad its running out when car is on. By the dip stick on drivers side.
Apr 17, 2010 at 2:15 PM
MMPRINCE4000
Experienced Mechanic
Check dipstick O ring, otherwise raise car and inspect engine. Clean engine with degreaser if necessary.
You can also use a dye in oil to trace leaks.
Apr 18, 2010 at 1:41 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
