2001 Pontiac Grand Am oil leak
2001 PONTIAC GRAND AM
170,000 MILES • 4 CYL • FWD • AUTOMATIC
JUNEBUGSUMMER619
very bad oil leak so bad its running out when car is on. By the dip stick on drivers side.
Apr 17, 2010 at 2:15 PM
MMPRINCE4000
  • 8,548 POSTS
Check dipstick O ring, otherwise raise car and inspect engine. Clean engine with degreaser if necessary.
You can also use a dye in oil to trace leaks.
Apr 18, 2010 at 1:41 AM
